  3. Derestricting
  4. 3DD model restrictions
6 Posts 2 Posters 200 Views
  • K
    K
    Kristóf
    wrote last edited by
    Hello everyone! I am the current owner of a 1988 swiss edition Yamaha Dt125R (3DD engine code). I've been having problems with power. I know it's restricted to 9kw but I'm wondering how. If I'm not wrong only the expansion chamber is different than on a full power dtr, on the other hand I saw someone on here post about cutting up a 3DD pipe and it only had a catalytic converter (which mine also has) but as far as I know the catalytic converter doesn't affect power, only sound and emissions.
    So now I'm wondering what I should try to get some more power out of it. Thank you for your help!
      wrote last edited by Calum
      From my experience, the catalytic converter was so restrictive that I cannot fathom how it possible could not have an adverse effect.
      I do think, leaving your pipe standard is really ideal, especially as these bikes are appreciating classics. Instead, just grab yourself a DEP pipe and be done with it, the weight saving alone is worth it!
      Do you have a powervalve fitted or is it fixed?
      • K
        K
        Kristóf
        I have the power valve fitted and it's functional. I'm thinking about selling this bike next year so if it's possible I'd rather not spend money on a new pipe. That's why I asked. I thought the catalytic converter didn't affect power but I guess I was wrong. Idk I might end up cutting the pipe up in the winter or have someone more experienced do it. Also because I want the bike to look mostly original and a shiny new pipe would definitely scream aftermarket. I also heard that after nearly 40 years the catalytic converter might got weak and brittle and that it's possible that a piece breaks off and the cylinder sucks it in which would cause an engine failure.
          I mean....
          As I say, I can't see how this doesn't affect performance!
          • K
            K
            Kristóf
            Oh. So there are no dead cones in the pipe? Just the cat? Because in that case I think removing it is quite straightforward and might not require cutting it completely in half. It might be possible to cut a window in the pipe and break the cat apart
              As far as I was aware the catalytic converter was only on the RE/X and not the early model, for the UK at least, not sure about everywhere else.
              Either way, there is definitely some great points being raised here with cutting the window option, any debris that get sucked back into the engine could be disastrous.
