Chinese cylinder kit
Hey! I have a 1988 dt125r and I've been having compression problems. The bike supposedly had a brand new piston, installed by previous owner. As it turns out the piston was incorrect size. The piston is somehow 55.1mm, even tho the smallest piston size should be ~55.98mm. The cylinder was originally 56.4mm on the inside, somehow that's 55.9mm on mine... after further investigation it turns out one of the previous owners decided it's a great idea to bore out the original sleeve and press in a second sleeve. This led to multiple issues: such as an undersized bore and incorrect port timing...
The cylinder is cracked in multiple places because of the double sleeve, therefore I need a new cylinder. I don't want to spend a small fortune on an Athena kit, and I also don't want to buy another used cylinder. Therefore I am left with only one choice: a Chinese cylinder kit...
The reason I wrote this is to ask if anyone had any experience with the aftermarket AliExpress cylinder kits, or if somebody could tell me any other, better options that could solve this problem
Thank you! -
I'm talking about this one. I'm aware that this is for a tzr125 but it's basically the same engine and it also says 3BN on the cylinder and in the description it also says 3BN-11311 which is the original cylinder part number for the 1988 Yamaha dt125r. Thank you
I bought (for a laugh) a Chinese RD350 cylinder last year.
I bought it for
Break in case of emergencysituation. It would be pretty woeful without significant porting work.By the time you spend the time/money on the porting work to actually make it useable, you may as well have bought the Athena kit and ended up with a better product overall.
A few years ago (my current setup) I bought an Athena 170 (brand new). Very good value for money and packs a nice punch. I cold seized it as I don't run a thermostat. I bought a used one off of eBay for £60 and had it ported by Mick Abbey. He was actually able to recover the Nikasil on this barrel and I've been running it ever since.
So why is a used barrel out of the question for you?
Edit: I must admit I haven't looked at the used DTR market for a very long time.
What you're getting in the box is incredible value for money. I think I paid that alone for Italkit 140 cylinder for my RS and still had to buy heads/powervalve/etc.
I don't want to spend a lot of money on it because I'm gonna sell the bike in like half a year... I realized the cylinder isn't actually cracked, it just looked like it was but it isn't. I think the best option would be to resleeve it because that way I keep the original cylinder with the original porting and I have a brand new sleeve. Resleeving is also fairly cheap compared to an athena kit
