  3. YPVS Servo Problem
YPVS Servo Problem
4 Posts 2 Posters 2.1k Views
  • CallumJ94C
    CallumJ94C
    CallumJ94
    I know it's probably been asked before but I can't find any answers. I got hold of a working 5 wire Servo with cables etc for my 2003 DTR (01 engine fitted)
    Plugged it in (Block & Bullet connector) and seemed to have no power going to the servo at all. No cleaning cycle etc. (Cables disconnected, Battery seems ok) Anyone know what the issue could be? Heard about a YPVS controller somewhere under the rear mudguard? Or possibly a fault with the CDI? Can anyone help? Cheers.
    • Louis-DT-WRL
      Louis-DT-WRL
      If you can, get it plugged into another dt to test
      • CallumJ94C
        CallumJ94C
        CallumJ94
        I have done so I know the servo motor is definitely working, just isn't working when plugged into mine. Is the white relay under the rear mudguard related to the YPVS?
        • Louis-DT-WRL
          Louis-DT-WRL
          Try swapping a cdi from the other bike to rule out its the cdi
