Engine revs don't climb past 2nd gear
General Discussion
7
Posts
Posters
1.3k
Views
Is that the 50cc minarelli engine?
Should be in the technical engine zone mind you.
What's the compression like.
Yeah but there isn't any load on the engine so it's not a fair test.
It could be a multitude of things, from bad ignition to bad fuel.
If the compression is good then it could be losing power through either the transmission or clutch.
