  3. Random flats
Random flats
4 Posts 2 Posters 2.7k Views
  • D
    DevonDtr
    So went on a ride, all good for few minutes and felt a wobble. Pulled into garage, which didnt have air pump so i had to use tyre repair foam. Noticed while i did this that the foam came out of the wheel under the valve, and a few of the spoke nipples. Still cant get it pumped up 😞
      Yes they are tube tyres mate. So it's not a tyre that provides the seal but an innertube. Tyre foam won't be of any use to you.
      Would have to ride it on the flat to get it home.
      I was always getting punctures. Couple of tyre levers and puncture repair kot. Easy enough to fix on the cheap.
      • D
        DevonDtr
        Another thing to fix lol never had puncture without an actual hole tho
        • D DevonDtr
          @DevonDtr Yeah but at least this could happen on any vehicle!
          I got so used to doing tyre changes that punctures were the norm.
          I had so many puncture repair kits on my DT that eventually it was the seam that split lmao!
          Deadly now that I think about it. A blow out down the dual carrige way could have ended really badly!
