Buying a Yamaha DT 125...
You could prize it away from me for the right money, 91 model 2 owners from new. Completely restored from the ground up.
@scrimsmustang how much is the right price scrim? I could be tempted I need to move a couple first ideally tho as I have far too many can you send me a few pics to my msg box please
@finnerz89 The later models have got to be the easiest to derestrict lol
@cyber-ninja Yes I have had my eye on the DTX for the most part when looking into this type of bike if I go for this it will have the 3MB head already? Which will tie in nicely with some other mods if I am correct?
As derestricting goes on the DTX I heard it's just to earth a wire running under the speedo don't quote me though!
Thanks for the reply! -
@calum said in Buying a Yamaha DT 125...:
Nah, if you can find an old one thats not been derstricted it was a doddle. Turn the powervalve round to fully open and put the peg and cover back on, exhaust off 3 spotwelds holding the restriction tube in the manifold wip that out exhaust back on job done.
@andrewj1680 said in Buying a Yamaha DT 125...:
I will probably be keeping it for a while now the Black one has gone to be honest.
@natnice Yeah nice.
For that sort of money you should get a lovely example.
More is going to be less with these ageing bikes.
Pay a little bit more for a bike that is in better condition, and it'll save you in the long.
But I suppose it all depends on what you want it for. These bikes are appreciating classics, if you are going to do lots of byways then it's nice to have an example which has been used for this purpose before.
If you it's a sunny day rider then a nice restored one will suit you.
@natnice Yeah nice.
Update!!
I've got my eyes on a bike and I got 2 questions.
The plastic shielding the front two forks can they just be removed or do I need different forks?And also the wheels from the images provided would you be able to tell if the wheels could fit SM tires instead?
Sorry for the novice questions haha I'm knew to the DTThanks
Nat -
Update!!
Nat@natnice That's a nice example.
I ran my bike without fork gaitors with NPs. But obviously they are their a reason as @Calum stated.
DT's in enduro form run a 21" front wheel and an 18" rear wheel. SM wheels are 17" so you would need to replace them if you wanted the SuMo look. Or you can stick with the stock wheels and just run road tyres, personally if you want the SM look I would just buy the DTX version. As that way everything is factory designed and needs no faffing about etc. Because if you want SM wheels and brakes you will need to swap the front forks, wheels, brakes from a DTX and ensure that everything lines up perfectly including the calipers, discs, sprockets and chain. Which will mean custom manufacturing some brackets and spacers to get it all to fit. So unless you are prepared to go down that road, then it's a choice of enduro or SuMo???
@cyber-ninja
Ahh right I understand sounds like a lot of faffing about indeed thanks for the info, with the enduro tires is it possible it get a thicker look then the ones he's got on currently they look a bit skinny in my opinion
