Reed block spacer
			Engine
3
Posts
Posters
2.3k
Views
Watching
Hi anyone know where the reed spacer goes ? As in which side of the reed block ? The inside ( on the engine , or the outside . ( between reed block and boot ?
Any help would be appreciated@seandtr They claim that depending on what you put it will depend on where the power is made. Something like before increases midrange and after increases peak power.
Whereever you decide to put it. Be sure to make sure it's well sealed. Last thing you want is air leak through.
