  4. Headlight bulb
Headlight bulb
6 Posts 2 Posters 982 Views
  • BluestoesonnoseB Offline
    Bluestoesonnose
    Hi, can someone please confirm which head light bulb is correct for a 2002 DT125R, as a H4 doesn't seem to fit my bike?
    Cheers
    2002 DT125R
      Cheers
      NINJAN Offline
      NINJAN Offline
      @Bluestoesonnose DTR's use a weird bulb in the headlight, which are quite hard to get hold of, as not many places stock em sadly. It is a H4 but they have a P45T bayonet fitting. You can order a direct replacement from someone like Wemoto;
      https://www.wemoto.com/bikes/yamaha/dt_125_r/99-00/picture/bulb_headlight
      Or you can upgrade to a P45T super white Xenon bulb like I did and you will get a more powerful brighter headlight;
      https://www.ebay.co.uk/itm/2x-HB12-410-P45T-100-90w-Super-White-Xenon-Headlight-Bulbs-12v/191434589033
      :grinning_face_with_smiling_eyes: :smiling_face_with_sunglasses: :grinning_face_with_smiling_eyes:
        Bluestoesonnose
        Cheers, I'll see if I can hunt one down, my headlight is doing odd things and I want to eliminate stuff
        2002 DT125R
          NINJAN Offline
          NINJAN Offline
          @Bluestoesonnose Some peeps have expressed concerns about using a higher wattage bulb, as it may put some extra strain on the rectifer (Charging unit?), but I experienced no problems when running them
            Bluestoesonnose
            Cheers,
            I've got a headlight issue and I need to know things are correct before I go off my gord trying to figure it out.
            I'll keep it all standard for now as I only plan to use the bike to commute in the city during the winter.
            2002 DT125R
              Cheers,
              NINJAN Offline
              NINJAN Offline
              @Bluestoesonnose Wise call - A stock bulb would ensure that you can track down any problems you have, without changing anything else or maybe adding anymore to the mix for-sure. :thumbs_up_medium-light_skin_tone:
