  4. Project DTZr.....a DT125R love story
80 Posts 14 Posters 23.0k Views 1 Watching
  • MadGyverM
    MadGyverM
    MadGyver
    #41
    Problem update
    I've checked everything twice the last days,fixed a damaged connector from corrosion that seemed ok,cleaned every connector and earth point,resolder a cable that was holding by a hair of copper,all stator coil's is in specs and tested,the used stator I purchased is ok also but no change when used it.
    Rectifier regulator checked and outputs the volts as it should (managed to start the bike for 10 mins run at idle,when gave some gas and reached 5000rpm engine shut off and did't run again,2 days have passed with trying).
    So the only thing that cannot be fully tested is the CDI.
    and a Project update
    I''ve managed to find a back wheel (17inch) from a TZR125 4FL that is exactly the same even in the lettering with the current 18inch from a TZR250 3MA.It's a little hard to find tires at good price for 18inches where I live.
    Will post pics when ready.Now the bike will be 3.00x17 front and 3.50x17 back and not the 4.00x18 back wheel that has now.
      Are you using a genuine Yamaha ignition coil?
      I've had this when I mistakenly bought a "Racing" coil off of eBay. Bike would initially run fine, then the coil would be saturated and the bike would barely idle let alone rev off! I had to ride back from Wales like this and it would struggle to do 50mph.
      Bought a brand new genuine coil and the problem went away.
      My brother had the exact same problem on his RD350, crappy Chinese coils...
      • MadGyverM
        MadGyverM
        MadGyver
        Bought a genuine ignition coil from yamaha 3 months ago,it worthed the price of 65 euro's,an aftermarket was at 40. I am using Yamaha part's only except the 170 kit.
        • MadGyverM MadGyver
          @MadGyver
          Do you know the ID number of your CDI bud? I’m guessing that you can use any early one if you have a 3 coil stator? I don’t know what the postage is to Greece but I’ve got one you could use to swap out and check if it is the CDI…
          MadGyverM 1 Reply Last reply
            HOTSHOT IIIH
            HOTSHOT IIIH
            @Calum Yep, happened to me as well!
            The actual coil on DTRs is very good quality so it's well worth fitting a new lead even to an older one; you can cut off the very top of the coil's outer case where the lead pushes in with a junior hacksaw, pull out the old lead and solder the new one to the coil output for a really good connection. Then re-waterproof using Shoe Goo and electrical tape. Looks messy but no-one can see it under the tank.
            I had a high-rpm misfire once, after trying everything else we replaced the HT lead in the manner described above which took around 1 hour on a summer's day so the engine was neither stone cold or up to temperature when I took it for a test ride. It wheelied out of the driveway without me even trying, and I couldn't believe how much better the performance was at all engine speeds. Made a big impression on me as I was 17 at the time and I'd spent practically a weekend trying to fix the bike and getting nowhere.
              @MadGyver
              MadGyverM
              MadGyverM
              MadGyver
              @SpookDog It's 3NC-00 and I have a 3 coil stator,it's a 1993 bike.What's yours CDI?
                @MadGyver
                I don’t know off the top of my head. It’s the postage that’s a potential issue…
                  @MadGyver
                  #48
                  OKay, it’s:
                  3NC -00
                  93N
                  Believe it, or not! 🙂 …
                  But I’m in the UK & have no monies till a week Wednesday (8 days) 😐 If postage can be sorted out I’ve no problems lending it to you for testing, or selling it if it cures your problems…
                  Have you swapped out the magnetic pickup? The wire can break inside the insulation where it exits the crank case…
                  • MadGyverM
                    MadGyverM
                    MadGyver
                    #49
                    @SpookDog Is it working ok?How much you will sell it (pm the price)?
                    No I did not,used the whole stator that came (a 3MB-00) but bike does the same like mine the 3NC-00.Both stators are with in specs,checked with a multimeter according the service manual.
                      @MadGyver
                      I don’t know what a fair price is. I can’t remember what I paid for it. Any suggestions people?…
                      • MadGyverM
                        MadGyverM
                        MadGyver
                        While measuring by curiosity,I noticed something not right.
                        Measuring point is battery connectors with a multi-meter.
                        Charging voltage with battery is 14.8v at 3000rpm,voltage without battery attached is 6.5v at 3000rpm.
                        I've managed to run it 2 time 2-3 mins each,the second time a dared to throttle it above 5000rpm it died no matter the kick start times no run.
                        Malfunctioning rectifier/regulator?
                        • R
                          R
                          Rallyfinnen
                          Some regulators will not work without a healthy battery
                          • MadGyverM
                            MadGyverM
                            MadGyver
                            For the 4th time I checked all the ground points for continuity,capacitance and resistance, all switches, coils.
                            Everything is in spec.
                            Every connector and contact will have dielectric grease for waterproofing and keep away oxidization.
                            • MadGyverM MadGyver referenced this topic on
                            • MadGyverM
                              MadGyverM
                              MadGyver
                              And it does EXACTLY the same,by hitting 5000rpm engine dies....wtf????
                              I have checked everything 4 times,everything is in specs.
                              I feel I am going down the @SpookDog road.......
                                @MadGyver
                                When you’ve tried everything that is likely, all that’s left is the unlikely…
                                I think mr shadi had to disconnect the wires to the read switch while the revs were above 6-7000 for it to work…
                                I’d read his post through to be sure though…
                                  But a 4DL CDI won't have the Reed Restriction in it? So that's irrelevant.
                                  It would be like plugging in a Zeeltronic ignition system and not earthing the Green/Black wire on the DTRE and then the Zeeltronic retarding the powervalve?
                                  • MadGyverM
                                    MadGyverM
                                    MadGyver
                                    @SpookDog The bike is an early one and has no restrictions to remove. For 1100km's was running ok and hitting 13000rpm on the road.
                                      Which is why I don't suspect the CDI...or reed switch.
                                      • MadGyverM
                                        MadGyverM
                                        MadGyver
                                        @Calum What can I check or test,any idea.
                                        I have read topics here and on the old forum,the Yamaha club forum but no solution resolve my problem.
                                        I'm on a dead end,followed the Yamaha service book,the Haynes, solutions from topics,whatever I could think,but now nothing.
                                          #60
                                          @MadGyver
                                          Sorry, I think I’ve confused you with another different thread. My bad 🫤 …Edit: Yeah, definitely misstuuke your Fred for another one. Sorry again. It was Har ptooie‘a thread I was thinking about…
                                          It doesn’t help that every time I try and read back through this thread I get thrown back to post number 6! Is there some kind of lag with pics loading up? (iPhone user)
                                          Do you have a power valve servo fitted? Have you tried running the bike with it disconnected? (If you do?) 5-6K seems like power valve territory…
                                          Just hunching at anything that seems relatable…
