  4. DTR 125 new piston ?
12 Posts 2 Posters 1.7k Views
  • B Offline
    B Offline
    Blaze.Vile
    Today I was riding home when my dt lifted, then went back down (without any loud noise, bang or anything). After that my bike has now got extreme amounts of pull, what feels like a very small power-band at the most and sounds like that of a 4 stroke engine, the bike sounds deeper and the engine feels a lot softer than it used to. Could this be a sign that I will need a new piston or could it just be an air leak ?
    • B Offline
      B Offline
      Blaze.Vile
      Also, the bike only gets up to 8k revs, feels like the powerband kicks in at about 5k instead of 6k and sounds nothing like a 2 stroke,
        You got the right colour powerband installed?
        B 1 Reply Last reply
          B Offline
          B Offline
          Blaze.Vile
          @Calum I believe so. It's the same power band that has been installed for the last 1500 miles (in which it has been running fine) the bike has also lost the signature "brap" a 2 stroke usually has.
            Best take the exhaust off and have a look up the port. See if the piston/bore is damaged.
              B Offline
              B Offline
              Blaze.Vile
              wrote on last edited by Blaze.Vile
              @Calum There is no rattle at all, could there still be a possibility of a new piston ? Or could I just need to re pack my end can ? As the bike was bought second hand with the exhaust system already on it I cannot tell you how many miles it has been used for.
              • B Blaze.Vile
                @Blaze-Vile Just take the exhaust off and have a nosey. Literally 10 minutes and you'll know if it needs a new piston.
                  B Offline
                  B Offline
                  Blaze.Vile
                  @Calum okay, just look for scratches on the barrel and wear on the piston ay ?
                  • B Blaze.Vile
                    @Blaze-Vile Yeah, see if the piston is damaged.
                    It could be that you have exhaust leakage.
                      B Offline
                      B Offline
                      Blaze.Vile
                      @Calum I've felt around the connections and I couldn't feel a leakage, No scratches on the piston or barrel either.
                        Power valve operating as expected
                          B Offline
                          B Offline
                          Blaze.Vile
                          @Calum The servo still moves it when the ignition turn on however the powerband opens up earlier than usual.
