  4. Dtr125 1999 power valve
3 Posts 3 Posters 578 Views
  • P
    P
    pauldopson
    I got a Dtr 125 1999 model. How do you turn the power valve to full power?? And it’s not like the older ones it’s got the Servo
    • P pauldopson
      @pauldopson well if your talking full power setting it up via your Haynes manual or adjusting the valve while checking through the exhaust port till there’s a smooth transition from port to valve is the best for power but I get the feeling you mean to pin the valve open?
      • D
        DTRLuke
        If you're pinning the P/V open, just remove the servo and wires.
