Engine casing discrepancies
Is it normal for two casings to be different? Specifically the inlet porting? The right side case doesn’t match the left by about 8mm! It’s an old 3bn that I don’t know the history of (eBay). I’m guessing that they two different year casings.
Is it best to match them or is it normal?..
Cheers -
Cheers -
Just to embellish a bit. These are 3BN 01 cases. I have some 3BN 03 cases that are totally different. The inlet port that ‘ups into the barrel’ doesn’t have the step, but does have a ‘flaired up step’ that I guess directs gas flow up into the barrel port. I’m just wondering how many different variations of 3BN engines there are?
I’m guessing that the 01 & 03 numbers are the year?
Cheers guys -
I agree! The bits I’m on about are internal though
How do you post upload pics from a phone. Do you still need to host the pic?
Cheers@SpookDog said in Engine casing discrepancies:
Cheers
I know it’s an old post, but I’ve only sussed out pics recently. Check out the casing join inside the inlet!...
What say yooz?... -
Cheers
What say yooz?...
