  4. 125 dt carb question
6 Posts 3 Posters 910 Views
  • T Offline
    T Offline
    tim85
    wrote on last edited by tim85
    Hi guys,
    Just bought a dt 125r from 1990.
    Got a question for the carb.
    Does the 2 circled pipes go anywhere or are they overflows?
    alt pic carb
    Thanks for the help!
    markus.wM 1 Reply Last reply
      They are carb warmer pipes.
      Coolant from the cylinder head go to the carb to warm it up!
      • T tim85
        Hi guys,
        alt pic carb
        markus.wM Offline
        markus.wM Offline
        @tim85 on my bike they are overflow/breather pipes as they connect to nothing, just directed downwards. I think The smaller lower one is for when you drain the float bowl. The carb warming pipes are on the other side and a bit higher. Sort of directly behind the choke linkage, 2 pipes quite close together and pointing upwards My warming pipes have just been removed and looped at the cylinder head by the previous owner. I guess they're only needed if you live in a cold country.
          Yeah sorry, not sure what I was really thinking. I jist said carb warming pipes for no discernable reason.
          I haven't seen that carb for years. I can't even remember where those hoses are anymore.
          The fact they are pointing down suggest that they are overflow.
            markus.wM Offline
            markus.wM Offline
            @Calum no worries mate. When somebody asks that question it usually is the warmer pipes they're refering to as I think they're quite a rarity. Well in the UK at least.
            • T Offline
              T Offline
              tim85
              Ok, thx a lot guys... it runs fine, but just wanted to make sure
