  4. 125 dt carb question
6 Posts 3 Posters 1.1k Views
  • T Offline
    T Offline
    tim85
    wrote on last edited by tim85
    Hi guys,
    Just bought a dt 125r from 1990.
    Got a question for the carb.
    Does the 2 circled pipes go anywhere or are they overflows?
    alt pic carb
    Thanks for the help!
      They are carb warmer pipes.
      Coolant from the cylinder head go to the carb to warm it up!
      • T tim85
        Hi guys,
        alt pic carb
        markus.wM Offline
        markus.wM Offline
        @tim85 on my bike they are overflow/breather pipes as they connect to nothing, just directed downwards. I think The smaller lower one is for when you drain the float bowl. The carb warming pipes are on the other side and a bit higher. Sort of directly behind the choke linkage, 2 pipes quite close together and pointing upwards My warming pipes have just been removed and looped at the cylinder head by the previous owner. I guess they're only needed if you live in a cold country.
          Yeah sorry, not sure what I was really thinking. I jist said carb warming pipes for no discernable reason.
          I haven't seen that carb for years. I can't even remember where those hoses are anymore.
          The fact they are pointing down suggest that they are overflow.
            markus.wM Offline
            markus.wM Offline
            @Calum no worries mate. When somebody asks that question it usually is the warmer pipes they're refering to as I think they're quite a rarity. Well in the UK at least.
            • T Offline
              T Offline
              tim85
              Ok, thx a lot guys... it runs fine, but just wanted to make sure
