Yamaha dt 125 clutch making a noise
@Tristan
Sweet , it’s definitely that, keep us informed. I like to know when things actually work out... -
@Tristan
Definitely sounds like something (a gear cog) is rubbing somewhere.
And there was nothing untoward about the engine? Nothing was lose inside? No metal filings in the oil?
Dude, if you can hold down the kickstart without it making the clacking noise while running it’s definitely it...
If you get stuck I have an old kickstart shaft assembly you could try swapping out. It absolutely has to bit it if it’s not making the proper noise when held down. It sounds like the cog isn’t going all the way back as it should...
