  4. Transmission oil leak
3 Posts 2 Posters 717 Views
  • T
    T
    tim85
    Hi guys,
    i have a transmission oil leak and seems to be the right side crankcase cover gasket. I can see a drop of oil hanging there.
    Is this hard to replace on a dt125r 1990? does the engine needs to come out?
    Do i have to take off oil and waterpump?
    Or just bleed everything?
    Would you suspect any other blown seals or gaskets?
    Thx in advance
    • T tim85
      Hi guys,
      Thx in advance
      @tim85
      It’s easy enough. You can do it in frame. Gaskets are cheap. Put some sealant on it as well...
      Oil and water pumps come away with the side casing. The oil pump (2/) will need bleeding. Do a search...
      T 1 Reply Last reply
        @tim85
        T
        T
        tim85
        @SpookDog
        Okay, thx! Ordered new gasket online and will try and install next week.
