  3. Dt 125r 95 cnc levers
5 Posts 2 Posters 988 Views
  • rking7888R Offline
    rking7888R Offline
    rking7888
    Re: Levers that fit 1990 dtr??
    Do the cnc levers (Chinese specials) go on all dt's fine no fiddling or modding required? Lots of people seem to be running them at the moment I suppose it's them or asv really, wish yz fitted would make life so much easier
      @rking7888 can just change the perch to a YZ if you want YZ levers.
      I run an Aprilia RSV Mille Lever on my DT with ASV.
      rking7888R 1 Reply Last reply
        rking7888R Offline
        rking7888R Offline
        rking7888
        @calum thanks mate, I was literaly just ebaying yz perches but I wasn't sure about the front brake will yz work too? I read somewhere about some not right to activate the brake light
        • rking7888R rking7888
          @rking7888 No there is obviously no brake lights on MX bikes. But you can use a Banjo switch and splice that into the loom instead.
            rking7888R Offline
            rking7888
            Any one know what size the steering stem bolt is on a 95the dome top nut? Accidently come across some anodised blue ones but only have 04-06 :-( defiantly become addicted to parts hunting lol
