  4. Blue wire stator to oil.sender
2 Posts 2 Posters 663 Views
  • D
    dan28
    There is a small.two pin plug that plugs into the stator a blue wire comes off it an goes to the oil sender
    If the oil sender is removed ( running premix ) do the wires on this plug have to be joined together does it stop the bike from starting ?
    dt200wrmanD 1 Reply Last reply
    • D dan28
      dt200wrmanD
      dt200wrmanD
      dt200wrman
      @dan28 no, assuming you mean the level sender in the oil tank, you can just unplug it and the bike will still run fine
