  4. Clutch damper
Clutch damper
8 Posts 3 Posters 1.7k Views
  • K Offline
    K Offline
    kevin
    Anyone ever sourced replacement clutch rubbers, mine are slack
    M 1 Reply Last reply
    • K kevin
      M Offline
      M Offline
      mhbikesnbits
      @kevin yes buddy I’ve done them not long ago if
      go on Yam bits and order
      RD350 YPVS LC2 Clutch Basket Damper Rubbers RD350 Clutch Basket Rivets
      You can grind the back of the old rivets off and use these ones, they are a different shape but they take all the play out of the clutch basket
      K 1 Reply Last reply
      • M mhbikesnbits
        K Offline
        K Offline
        kevin
        @mhbikesnbits nice one fella, thanks, saw some that look identical online in Malaysia TZM150 but they won’t post out.
        • K kevin
          M Offline
          M Offline
          mhbikesnbits
          @kevin i did a little research and the ones I sent you were best option it seems, haven’t got any play at all now really in mine a lot better than how it was originally
          K S 2 Replies Last reply
          • M mhbikesnbits
            K Offline
            K Offline
            kevin
            Saw a YouTube on this ( was that you ) but think I have sorted it with a mixture of Dt125r and Tzr250 rubbers, picture posted on Tzr forum. Thanks again.
            • M mhbikesnbits
              @mhbikesnbits
              How much do the rubbers & rivets cost bud?...
              S M 2 Replies Last reply
                @mhbikesnbits
                @SpookDog
                I’ve got three baskets with differing wear on them. The only thing in common is the amount of slapping movement on the buffers. About 5mm...
                I’d love to see a new/low mileage basket to compare movement...
                  @mhbikesnbits
                  M Offline
                  M Offline
                  mhbikesnbits
                  @SpookDog sorry for late reply all in with post was around £20 I think
