  3. Suspension
  4. How can i stiffen my rear shock? (2006 RE)
3 Posts 3 Posters 995 Views 1 Watching
  • AzeratorA Offline
    AzeratorA Offline
    Azerator
    Hi guys, i have a 2006 DT125RE that i converted into a supermoto and i`d like to make my rear shock stiffer, I already figured out the front fork stiffening, but im not entirely sure how i will go about stiffening my rear shock, can i just replace the spring? If so, what springs would fit? Or can i just replace the entire shock with something adjustable? Afaik a YZ shock would not fit, and the only aftermarket shock i found is a YSS for 230 euros. Any help is appreciated, thanks in advance.
    • AzeratorA Azerator
      @Azerator YSS make quality shocks so that's always a good option.
      The other options would be to fit the DT230 Lanza shock absorber as these appear to be adjustable.
      Unfortunately the Lanza is a JDM only model, so you'll need to scour the appropriate Japanese auction sites to find one.
      https://www.jauce.com/auction/w1051235526
      I have seen these fitted to R/RE/X models before.
      • M Offline
        M Offline
        mhbikesnbits
        Let you in to a little secret the xt600 shock spring fits into to the dt shock, either that or YSS shock is a good upgrade according to the guys on here which I am going for personally
