  4. Vin Numbers (frame & engine)
yamaha dtrvinframeengine
10 Posts 4 Posters 4.8k Views
  • Hybrid_Theory01H
    Hybrid_Theory01H
    Hybrid_Theory01
    From 1995 yamaha upgraded their alphabet to a more complex font and also the way they marked the VINs, what about engine markings where they dotted like Ducati for example or regular CNC/ laser etched? I heard there are DTRs with dotted engine numbers but i’ve Seen only regular markings
    markus.wM S 3 Replies Last reply
    • Hybrid_Theory01H Hybrid_Theory01
      markus.wM
      markus.wM
      @Hybrid_Theory01 my 1999 is not dotted just regular.
      Hybrid_Theory01H 1 Reply Last reply
        Scootjockey
        @Hybrid_Theory01
        Of what I’ve seen from 80’s 90’ to 00’ Yes they have changed the engine casing numbers in line to match the frame numbers. In size and font. Not that I would ever advocate such an illegal and treacherous action but I have seen where the engine casings were blasted and polished and painted to such a degree that the numbers (all original by the way) were put on using a rub on letraset. Then clear lacquer coated coz the paint filled the original numbers.
        • markus.wM markus.w
          Hybrid_Theory01H
          Hybrid_Theory01H
          Hybrid_Theory01
          @markus-w 4BL model?
          markus.wM 1 Reply Last reply
            markus.wM
            markus.wM
            @Hybrid_Theory01 yes. 1999 4BL model.
              markus.wM
              markus.wM
              @Hybrid_Theory01 around 1996 Yamaha moved production of engines and frames to separate factories, that's why they stopped matching the numbers so maybe there's a connection to the font changing.
              Hybrid_Theory01H 2 Replies Last reply
                Hybrid_Theory01H
                Hybrid_Theory01H
                Hybrid_Theory01
                @markus-w font changed in order to increase the difficulty of faking the alphabet and also at this moment the VINs were no longer written with "punches", my 1999 DE03 has the same number for the engine and for the frame (DE means it was made en egypt) this model is very common in germany.
                  Hybrid_Theory01H
                  Hybrid_Theory01H
                  Hybrid_Theory01
                  @markus-w I heard a theory today that the way the numbers are written (laser etched, CNC engraved or dotted might be because of different factories (probably different on different counties) saw a picture of a Japanese made 4BL and the engine numbers were dotted
                    markus.wM
                    markus.wM
                    @Hybrid_Theory01 there could well be some truth in that because Yamaha stopped matching engine/frame numbers on later models and I read that it happened in around 1996 when production of engines and frames were moved to separate factories.
                    • C
                      C
                      Carl Kennedy
                      Hi all. is there any way to find out my engine year as it says 3py-001. at 1st can't find anywhere to check engine numbers and make of it.
