  3. Suspension
  4. Washer in fork position?
3 Posts 2 Posters 1.3k Views
  • S
    Can anyone please tell me where the washer is supposed to be in the fork leg? Under the seals or between them?
    The manual isn’t helpful as some bikes have 2 and some 1. Mine only has room for 1 but I don’t know where it goes 🙂
    I never had any fitted to the forks I have, but there is a gap for them…
    C 1 Reply Last reply
      C
      C
      CalDT125
      @SpookDog said in Washer in fork position?:
      Mine come out below the oil seal, so in order bottom up it was guide bush then washer then oil seal then cir clip then dust seal. Certain models have one installed either side of the oil seal but mine just had below installed, hope this helps 👍
      • C CalDT125
        @CalDT125
        The dust seals supposed to be under the curclip isn’t it? Mines quite loose compared to the oil seal and would pop out if it wasn’t under the seal…
