  3. Wheels
  4. DT125X speedo drive dimensions?
2 Posts 2 Posters 996 Views
  • B
    B
    bird902
    Hi everyone!
    Does anybody have dimensions of Dt125X speedo drive (part number 2C82519000)
    My bike is 60 miles away from me in the garage and I won't be seeing it for a few weeks but I need to order new speedo drive so it can arrive on time. Does anybody have dimensions of it? Since I can't find the original one that isn't 100 pounds I opted out to buying aftermarket but I need the dimensions
    Thanks!
    • B bird902
      Hi everyone!
      Thanks!
      @bird902
      Even if the width and diameter are the same there’s no guarantee that the inner gearing will be right, or even the proper drive teeth inside. Those cheap things off of eBay are total shite, even if they fit…
      IMO Original parts are the only way to go with parts like these…
      Is yours mendable? The teeth ring inside often gets bent and just needs straightening. That or used parts…
      If the Dtx is the same as a Dtr part you’re looking at about £40 second hand…
