  4. Engine break in after rebuild
3 Posts 3 Posters 854 Views
  • E
    E
    erionmustafa
    Hi i just did a top end on my 1997 dt125r i heard that you should take it slowly after rebuilding it not give it much gas and all that what should i do to be safer
    • R
      R
      Rallyfinnen
      If it's a standard cylinder with iron sleeve it is more important to run in, a nicasil cylinder is not so critical. With iron sleeve, first do at least one heat cycle only idling. You can add an extra 1% oil to the fuel the first tank or so.
        I think the main thing are the piston rings bedding in.
        I haven't worried about it too much. 50 miles if it's just a top end. But I am quite happy to rebuild the engine prematurely.
