  4. gasket identification
8 Posts 3 Posters 1.4k Views
  • E
    E
    erion1
    hey im buying a gasket kit from a guy but it looks a bit different i asked him for a athena gasket kit and he sent me this photo https://imgur.com/gallery/G96JKDw , can someone tell me if its athena based on the photo?
    • E erion1
      @erion1
      Do a search for Athena on the web and check what brand paper they use for their gaskets…
      I’ve never had an Athena or vertex gasket that has more than one hole where the coolant runs up from the bottom end and into the barrel, to the head in the head gasket. So no…
      E 1 Reply Last reply
      • MadGyverM
        MadGyverM
        MadGyver
        @erion1 Head and base gasket is for TZR125 2RH
        • MadGyverM MadGyver
          E
          E
          erion1
          @MadGyver do they work on dt125r? 3mb head 3mb00 cylinder
            @erion1
            E
            E
            erion1
            @SpookDog the bottom gasket only has one hole what do you mean by that?
            • MadGyverM
              MadGyverM
              MadGyver
              @erion1 Better get for the DTR a specific gasket set.
              The TZR125 2RH head gasket is thicker and designed for the massive head water jacket and a bigger rad that engine has.
              The bottom one is thinner at the sides and thinner as material,not a good fit also.
                E
                E
                erion1
                @MadGyver oh okay will check for a exact firt then thanks
                • E erion1
                  There has to be somewhere in Europe that ships to Bosnia?
