Replacing the stock rear shock with a cr 85 reiger one.
Hello.
I wanted to ask if i can replace the stock shock with a reiger or rager rear cr 85 shock. The dimentions are close (height 400mm) but i am worried that it will be too weak. Can i switch it or should i get a bigger one?
Il post a pic in the comments
Use the one that looks like a framed pic of two mountains and a moon. Third from the left…
If it’ll fit I expect it’ll be ‘strong’ enough, considering a Cr is a dedicated off road bike…
It’s definitely better spec’d with the adjustable damping…
