  4. Dellorto 28 mm carb settings
1 Posts 1 Posters 894 Views
  • D
    dan28
    When using a dellorto carb what jets should be used
    It's off a tdr/ tzr
    I was told to run on the Dt it needs a 170 main jet ( the one fitted is a lot smaller )
    Will I also need to the needle if so what size
