Gearbox breather blowing
Hello,
I’ve been having a few issues with oil leaks.
I can’t seem to stop loads of oil blowing out of the breather. Oil level is fine and case is pressurising. Does anyone know what is most likely the culprit before the parts canon gets fired? 😂
Oh, and no coolant is making it in as oil is completely clear.
If you're not getting coolant into the oil then it sounds like it's the right hand crank seal.
This can be done if you're careful with the engine in situ, although I always the split the crank cases.
Do a compression check to see if it's leaking through the cases.
Nice one, thanks for that suggestion! I’ll give that a go.
Ps. Nice name!
