  4. DTR 125 1994 Manual
DTR 125 1994 Manual
5 Posts 2 Posters 1.0k Views
  • A Offline
    A Offline
    Alexwych
    Anyone know where to find a Manual for a DT 125R specifically the 1994 Model ??
    • A Alexwych
      @Alexwych Have you tried searching?
      https://dt125r.co.uk/topic/3258/yamaha-dt125r-200r-workshop-manual
      A 1 Reply Last reply
        A Offline
        A Offline
        Alexwych
        @Calum ye but links either didn't work or they weren't from 1994 and just
        wanted to compare it to the other ones
          Those links work fine for me. The '88-04 models are relatively the same so should be good. Otherwise the Haynes manual is very good,
            A Offline
            A Offline
            Alexwych
            @Calum Thank you saved me some time looking around as I bought a dt and within less than 3 days it blew up and needed a top end rebuild and also the electrics and the water pump needed redoing hence why I wanted the '94' manual
