  4. Dt125r 1990 raspberry red
2 Posts 1 Posters 829 Views
  • G Offline
    G Offline
    glynn6500
    Re: 1988 rebuild update
    Hi there where did you find the Silver seat cover as I’m trying to find an original cover as the aftermarket covers are crap they don’t cut them the right way for stretching around the curve in the seat. Started rebuild mine back in 2017 complete strip and rebuild every ring and replace every nut bolt washer was missing the head so the Conrad was seized solid It had been sat outside for 20 years so you can imagine what it was like.regards Glynn
    G 1 Reply Last reply
    • G glynn6500
      G Offline
      G Offline
      glynn6500
      @glynn6500 said in Dt125r 1990 raspberry red:
      Hi there where did you find the Silver seat cover as I’m trying to find an original cover as the aftermarket covers are crap they don’t cut them the right way for stretching around the curve in the seat. Started rebuild mine back in 2017 complete strip and rebuild everything and replace every nut bolt washer was missing the head so the Conrad was seized solid It had been sat outside for 20 years so you can imagine what it was like.regards Glynn
