  4. Spark only when ignition is off
3 Posts 2 Posters 492 Views
    juntunen
    Hello i am quite new to bikes ive owned quads before and 2 weeks ago got my first bike (2006 yamaha dtx 125) i test drove it at the sellers house and everything was fine but after i got home it would no longer start and only has spark when the power is turned off from the ignition so if anyone could give me some tips i would be grateful
    Everything ive tried:
    Check and clean grounds
    Bypass the ignition switch
    Get a new ignition switch
    Removing the kill switch
    Bypassing the kickstand safety switch
    Replacing electric connectors
    • G
      G
      gary76
      Do a continuity test on the wiring loom first see if any bad wires
      I had exactly the same problem and did what you have done
      mine turned out to be a bad CDI
      J 1 Reply Last reply
      • G gary76
        juntunen
        @gary76 i do have the meter but i dont really know how to use it could u help?
