  3. Welcome New Owners!
  4. Where to start?!
Where to start?!
2 Posts 2 Posters 347 Views
  • R
    R
    rhodes5150
    Hi all, I've just managed to acquire a 1990 125R which has been stood for some years. In in Plymouth, South Devon and am looking for a parts supplier and possibly mechanic. I'd love to strip and rebuild this myself but may not get the time. And will need a rolling road tune at the end too. Any supplier to use/avoid would be helpful.
    So to the tech, starting at the bottom............new balanced crank or keep existing if condition ok? Athena 170cc kit or other options? Exhausts? A few to chose but I start and end with power. Any advice as to which livens the engine up the best. Reeds should these be upgraded? I've had two strokes before but not with these valves.
    Thanks
      Hey @rhodes5150,
      Nice early example which should hopefully be full power.
      Best thing you can do with these is to start by getting them full stock. That's a derestricted CDI (yours sounds like it should be), then making sure you've got a working YPVS system which is setup correctly.
      If the engine is sweet, then leave it alone for the time being. If it's aged and worse for wear, then getting it rebuilt is the way to go. These engines are incredibly simple and easy to rebuild with no specialist tools required. Can drop the bearings in by using a conventional oven heating the cases up.
      Checkout Yamaha DT 125 r derestriction to see what's needed for your bike.
      Once you've got the stock motor running sweet, and you still want more power then here are a list of mods I'd do (haven done most of what can be done, experience tells me this is the best order and bang for buck).
      • Exhaust System
        • Full DEP system
        • Really perks up the mid-range punch
        • Cuts out significant weight over the stock system
      • Zeeltronic Ignition System
        • Over my DTRE/X (pretty restricted CDI) really punches up the midrange
      • Carbon Reeds
        • I run VForce4 Reed block on my DTR
        • But generic carbon reeds can help
        • Mileage may vary I'd struggle to tell the difference
      • Porting work
        • Making sure the head/squish is correct is where you'll get the most gains
          • Cheap to get someone to do and can make or break a two stroke
        • Having the cylinder done can be more expensive and mileage may vary on this
      • Athena 170
        • I've grown to appreciate the 170 kit
          • It doesn't compare to RS 125 big bore kits or other extreme setups
        • Massively increases the mid-range (reducing overrev)
        • Makes the ride much easier to live with
        • Of course this can also be ported to make additional gains here.
      You can do other mods, such as skimming the flywheel. This doesn't give you any more power per se, but allows the power to be obtained faster. This can drastically affect the overall performance though, so sometimes it's best to leave it alone.
