  4. Forgot where wires go...
7 Posts 2 Posters 345 Views
  • S Offline
    SomeRandomGuy413
    Can any of you please take a picture of where the wires go here on the left and right side as I forgot to take pictures before dissasembly.
    Here are references I need.
    https://files.fm/u/jke4m3pu8s
      The right attaches go the airbox. It's the main power cable. So the positive terminal for the battery attaches to it.
      The one on the left looks like the CDI wires, so attaches to the frame.
      • S Offline
        SomeRandomGuy413
        The one on the left are the wires from stator, and there are 2 seperate wires, one with many other wires and one at the bottom all alone. I dont remember where these 2 go.
        • S Offline
          SomeRandomGuy413
          Also what goes on the empty bolt on relay?
          • S Offline
            SomeRandomGuy413
            Is it normal too, that I only have 1 red thingy on relay?
            • S Offline
              SomeRandomGuy413
              Ok, I think I connected everything correctly, but the neutral light is not lighting up and Im guessing its because of this wire. I just dont know where to connect it. If anyone has any idea, please help.
              https://imgur.com/a/bGXzwAe
                Sadly Imgur is no longer accessible in the UK. So I am not able to see the photo.
                But in essence, yes the bullet connector for the loom connects to the neutral switch on the gearbox. So using a spade connector and a wire to go to the bullet connector.
