  3. Welcome New Owners!
  4. Noob
Noob
6 Posts 3 Posters 532 Views
  • R
    R
    Rat80y
    Hi everyone
    I got myself my first bike, a DT125 R.
    It seems to have a issue reving past 6 6.5k, I think it was still cold and the choke was on, but he is adamant it was off. I was going to see if the pv was doing its cycle when turning the bike on
    I have the parts to do a plug and fluid change but was wondering what else it could be?
    Any help appreciated
    • R
      R
      Rat80y
      Its a 2000 model
        With the choke on and it being cold, I'd be reluctant to rev it past 6500.
        The 2000 models were heavily restrictive, so going over it all and ensuring it's full power and healthy would be where I'd start.
        See @scrimsmustang's guide for derstricting.
        https://dt125r.co.uk/topic/3492/yamaha-dt-125-r-derestriction
        Do a compression test, make sure the engine's healthy. Check all the air ways, that the exhaust is free of water/oil. That the airbox is clear and the filter has been changed. Check the carb and jets make sure that they're all clear and not blocked.
        I'd pin the powervalve open for the moment, just to eliminate it from being a problem source. This will drastically reduce power low down, but should rip roar to the red line.
        • R Rat80y
          Its a 2000 model
          HOTSHOT IIIH
          HOTSHOT IIIH
          @Rat80y I don't have a great deal of experience with the 2000 models with (usually) 5-wire servos etc. so what @calum said.
          I'd definitely do a full carb clean including the emulsion tube (the brass tube the main jet screws into). A lot of people (including bike shops) miss this and don't realise it comes out because you have to screw the main jet back in without the brass washer and tap it gently to remove it from the carb body. The space between this and the carb body gets blocked with moisture, dirt etc and blocks more and more holes in the tube (which is how the air atomises the fuel) until it just starts fourstroking and won't rev out one day as this controls the mid-throttle fuelling. Just chucking it in an ultrasonic cleaner usually isn’t enough; you have to actually remove everything from the carb body, physically make sure all the jets and air passages are clear, then reassemble. Make sure the air supply to the emulsion tube is clear as well, it's the small brass tube on the right of the carb body just in front of the carb-to-airbox rubber. You should be able to blow through it, but only just.
          Oh and BTW the float height on the flat slide TM28SS carb is 15.5-16.5mm despite what Haynes says, they got their TM28SS mixed up with the earlier VM26SS round slide carb whic was only on 1988 DTRs. Hope you get this sorted buddy.
          • R
            R
            Rat80y
            Thank you both for the advice, im going to change all the fluids, new filter and plug and some fresh e5 fuel.
            Ill see how it is after this as I wasn't able to find a carb kit, so dont want to pull the carb untill I can get a gasket really
            • R
              R
              Rat80y
              Glad to have give it a once over
              Bent oil sump bolt
