  4. New member needing advice
10 Posts 3 Posters 830 Views
    JOHNES
    I all, I am a new member and i have a 2004/05 DT re which has been stored for a few years and is now a non runner due to no spark. I have tested the coil and it is goosed. Are the cheap coils on E bay any good and are the so called racing coils which are supposed to provide a stronger spark worth the extra money.
    • J JOHNES
      HOTSHOT IIIH
      HOTSHOT IIIH
      @JOHNES Welcome to the Forum buddy, unfortunately those aftermarket ignition coils cause all manner of problems on the DTR/DTRe. New genuine from Fowlers (or your nearest Yamaha stockist if you're not in the UK) is worth every penny.
      Are you sure it's the actual coil that is causing the problem, or could it be the HT lead? They break own on DTRs causing this exact problem. The actual coil is very good quality so it's well worth fitting a new lead. On early DTRs you can cut off the very top of the coil's outer case where the lead pushes in with a junior hacksaw, pull out the old lead and solder the new one to the coil output for a really good connection. Then re-waterproof using Shoe Goo and electrical tape. Looks messy but no-one can see it under the tank, and you should notice a performance increase as the leads deteriorate over time. Much better option than just buying a new pattern coil as these often have different specs to OEM which can cause other issues. Fit a new NGK cap while you're there, try to get the type that's moulded into a single piece of rubber.
      I had a high-rpm misfire once, after trying everything else we replaced the HT lead in the manner described above which took around 1 hour on a summer's day so the engine was neither stone cold nor up to operating temperature when I took it for a test ride. It wheelied out of the driveway without me even trying, and I couldn't believe how much better the performance was at all engine speeds. Made a big impression on me as I was 17 at the time and I'd spent practically a weekend trying to fix the bike and getting nowhere.
        JOHNES
        This post is deleted!
        J 1 Reply Last reply
        • J JOHNES
          [[topic:post-is-deleted]]
          JOHNES
          JOHNES said:
          HOTSHOT III thanks for the reply. I am pretty sure the coil is knackered. I tested it with the multimeter and got a reading of .0005 ohm on the primary and nothing at all on the secondary so I think the coil and the plug lead/cap are both knackered. There are a few little jobs that need doing but I do not want to spend money on them until I get it running. I am going to price one up at Fowlers as you suggested. The last time I started the bike it ran for about 20 minutes and was idling nicely as it always did then it cut out and would not start. I still had spark then. I took the carb off and cleaned it but did not find anything wrong and then the battery died and it has not been started since so I need a spark to see if the carb is ok. The bike has only done 11,300 miles and is in generally good order so I hope I can get it running again. I was planning to MOT the bike then sell it but I might change my mind and keep it. Just checked Fowlers but they are out of stock.
            Definitely don't buy an aftermarket coil they are useless!
            Go OEM or don't bother. I'd be surprised if it is the coil, but given the availability of the bike, finding another one shouldn't be too tricky. I bought a brand new genuine one not too long ago as I made the mistake of buying a Chinese one and it causing all manner of problems.
              JOHNES
              Hi Calum, have you seen the Japanese made Mitsubishi coil for sale on yambits. Would you consider this aftermarket crap or OEM equivalent?
                The OEM ones are apparently made by GPR or Tourmax.
                One manufactured by Mitsubishi should be of sufficient quality, Mitsubishi supply into Yamaha for a lot of other parts these days.
                Can you link the one you're looking to buy?
                Presumably it's this one:
                https://yambits.co.uk/dt125re-ignition-coil-mitsubishi-japan-p-222065.html
                Yambits is a quality website, so should be reliable and Mitsubishi is not going to mess about with subpar coils.
                  JOHNES
                  Hi Calum that is the one I saw but I decided to play safe and get the OEM one from Fowlers. It would be interesting to see if anyone has tried one of these and if it worked ok or not. I also looked at buying a new plug cap from Fowlers but they do not stock them any more but at 32 quid I would not have bought one anyway.
                    I just run an NGK cap for mine.
                    https://www.pjme.co.uk/acatalog/NGK-Spark-Plug-Cap-Racing-Red-1550.html
                    Pretty sure I run an NGK lead as well to be fair.
                      JOHNES
                      Hi Calum, the OEM coil I ordered has arrived from Fowlers but the clear autolube pipe I ordered from e bay has not arrived. It is showing as running late when I check the tracking. I do not want to start the bike until the clear oil tube is fitted and bled so I am at the mercy of Royal Mail. Assuming the bike will run the only thing left to do is a couple of bulbs and then it should be ready for its MOT. I will fit a new plug cap similar to the one you show.
