  4. Bad vibrations
Bad vibrations
6 Posts 2 Posters 2.6k Views
  • dtlukeD
    dtlukeD
    dtluke
    wrote on last edited by dtluke
    Anyone ever rebuilt their engine and then had really bad vibrations at high revs?
      Sounds like you haven't time the engine up properly bud. The balancer shaft must be timed up with the crankshaft.
      It's not a split case job, but you eill have to strip the clutch basket
      dtlukeD 1 Reply Last reply
        dtlukeD
        dtlukeD
        dtluke
        @Calum As I don't understand what you've just said this definitely sounds like my problem. Will do som research, cheers
        • dtlukeD dtluke
          @dtluke Inside the gearbox next to the primary shaft and the crankshaft, that odly shaped item is the balancer shafter. It harmonically dampens the engine. It is locked into place by the crank shaft. The crank to shaft is pulled to tdc, and two dots meet at their circumference.
          If you don't, the engine will be out of nalance and will demolish the mains and gearbox.
            dtlukeD
            dtlukeD
            dtluke
            @Calum Cheer mate! You were spot on. Took it apart again. Lined everything up and just went out for a ride and she's better than even. first proper engine rebuild and it seems to have gone pretty well minus a few hiccups. Next one will be super smooth now.
            • dtlukeD dtluke
              @dtluke Yeah nice man.
