  3. Wheels
  4. Where on the loom do brake light switches connect
7 Posts 3 Posters 2.0k Views
  • D
    dan28
    Just been looking at my loom it's all labeled up
    I ve just noticed there doesn't seem to be any thing that connects to the brake light switchs ?
    • D dan28
      @dan28 From memory there should be 3 wires at the end of the loom. One yellow, one blue and one black.
        That sounds abput right.
        • D
          dan28
          What other wires are they near on the loom as I don't seem to have them
          • D dan28
            @dan28 You also just use a banjo switch if it's been chopper mate. Really simple and nice way if doing it if you have to.
            D 1 Reply Last reply
              dan28
              @Calum said in Where on the loom do brake light switches connect:
              I would rather use the original plugs in the loom as I am going to have to route the loom internally through the frame if I use a banjo it will make routing it more difficult
              theres a square plug on the rear of my loom it has 3 wires , yellow ,black ,blue/red but its labelled as tail light
              • D dan28
                dan28
