carb air screw
My understanding is the DT has a mikuni vm26 carb,does anyone know if this air screw will fit, thank
shttp://www.ebay.co.uk/itm/121860296756?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT@scotty I'm not sure, I know not all carbs are the same as it depends on the year of your DT. If I had my haynes manual handy I'd gladly list you the names, unfortunately I don't. Although it's possible the screw is the same on each carb. Either way, I know someone on here will know the answer without having to check the book
@Minia said in carb air screw:
I'll get a pic,it might help -
@Ricky said in carb air screw:
Depends on the year of the dt mines a 28mm
28mm,is that inside or outside diameter?
