  4. DT pipe
DT pipe
5 Posts 4 Posters 1.6k Views
  • K
    K
    Killersbeez
    wrote on last edited by Killersbeez
    Hi,Sorry if this has been answered but I couldn't seem to find an answer to my question. Does DT exaust pipe(expansion chamber),like for example DEP fit to TDR or vice versa?
    Thanks.
      Whilst the pipe may mount up with the cylinder, the frames are different and I doubt the mounting points are the same.
      I haven't heard of the DTR pipes fitting correctly on the TDR, but I don't own a TDR.,
      • terry.tzT
        terry.tzT
        terry.tz
        I personally doubt it but things can be made to fit @Mightyman might just might be able to shred some light on the matter he has a TDR I believe
        don't see why you would do this tho my understanding is dirtbike pipes are designed for low down power and road bike pipes are designed for top end power or do you mean under slung pipes for sm's
        • terry.tzT terry.tz
          @terry-tz Well it's the same engine in the TDR's and they're not exactly savage bikes.
          • NottsbikerN
            NottsbikerN
            Depends which TDR you've got.
            If its the deltabox one then no as they have their own unique fit, where as the Italian ones are / appear identical to DT-R ones. The other bonus is that I doubt the Italian ones were ever restricted.
