Routing of the loom
Another 1 for you guys an I right in thinking the loom on a dt comes through in between the front mudguard and the bottom yolk on the forks?
@andrewj1680 yes , there is the slot for loom on the on mudguard and it goes between the Y cowl bottom bracket and yoke as well up
@zrako ideal thank you, I've been searching for hrs on the net for some sort of picture to see if it does your a star you've put a end to my headache
