  3. Redlining issue?
Redlining issue?
42 Posts 4 Posters 10.9k Views 1 Watching
    https://youtu.be/SuybB1n7AlA
    @declan just fitted a new fuel tap hoping it would fix it but seems to have not I rode it the other day and it was stuttering at 7and8k although when riding it does ride as normal other than the problem above do reeds have a break in period
      @declan Not that I am aware of.
      I don't think rev'ing it to the red line is going to help/prove anything.
      It's not a realistic representation of how the engine is going to operate, since there is no load on the engine.
      If the engine is struggling to pull, it's either a weak engine, incorrect fueling or weak spark.
        @calum no? It rides ok runs great and tons of power but it’s stuttering at redline as the video shows
          @Calum from what I remember the redline was nice and clean
            It's possible then, that those reeds are not helping.
            I can't say I red line mine at all, the power curve drops off and it is more perform-ant to change gear. It's not worth the added wear and tear at those RPM's
            declanD 2 Replies Last reply
              @calum so shall I just try using it then since I’ve only rode it for a few minutes?
                @calum my power comes on really high up the revs and being restricted my rev band isn’t large like yours might be
                  It's not a crosser, I can't say my powerband is exactly savage. It comes on nicely and pulls to the red line, but it's derestricted and modified.
                  Yours presumably is still restricted and modified.
                  SO any modifications are likely to push the powerband up further, not great if your bike is restricted to a lower RPM. A Zeeltronic is a must if you want to tune these bikes.
                    @calum I’d be happy with just a de restriction but the code you asked me to get off the cdi has rubbed off so I got no idea how to do it do you think that a garage could figure it out?
                      @declan No I do not.
                      The plug types are probably different. One had 3 wire servos, the other used 5 wire servos.
                        @calum you talking pv? If so pretty sure mines 3
                        • declanD
                          @Darty @scrimsmustang any ideas lads?
                            I'll say that again, three wire servos are the newer models, the older 5 wire servos ran a separate controller.
                            Therefore yours is probably newer, probably a 3RM
                              Might have good luck just Googling mate. Rather than pestering people. If they know they'll chime in.
                                @calum so it’s an older bike with newer electrical components
                                  @declan Not my area of expertise I'm afraid. Only worked on 2001 and 2005 DT's
                                    @calum didn’t realise I was pestering it’s there choice? And I’ve looked all over and studied the de restriction manual and just can’t figure it out but I guess it’s not important any way
                                      @declan Their Nah mate not at all, but this isn't a busy forum. But ultimately we can't depend on anyone person to figure it out for us. They'll help if they can.
                                        @calum spell correct sorry, I was trying to be polite as to ask them for help but I guess you’re right
                                          @declan I was agreeing with you by saying you're not pestering by the way. I dunno, I kinda feel that when you ask them explicitly, that they feel like they have to respond.
                                          Which is why I don't mind picking up threads when I see them, but ultimately disabled my chat because people were just asking me directly, as if it's my problem to solve lol. Gets old pretty quickly.
