  4. Dt125RE overheating
Dt125RE overheating
12 Posts 4 Posters 2.1k Views
    Did you bleed the cooling system?
    Where did you buy your head gasket. Only Genuine or Athena head gaskets can be used on these engines
    • B Offline
      B Offline
      Bananper
      No, just refilled. How can i bleed the system?
      I think it's a Athena gasket, black one.
      • B Bananper
        Irongamer727I Offline
        @bananper you obviously have to mix some water into the coolant. Doubt concentrated coolant will cool very good.
        B 1 Reply Last reply
          B Offline
          B Offline
          Bananper
          @irongamer727 okay, thanks!
          • B Bananper
            @bananper go for a 50/50 mix
            • B Bananper
              My Dt is overheating, i just changed the head bearing, and filled up the radiator with concentrated coolant.. without mixing water in it, could this be the reason?
              @bananper yes of course mix the coolant properly your will end up damaging things if you don’t follow the instructions and when you have done a 50/50 mix of water and coolant bleed the radiator
              declanD B 2 Replies Last reply
                Sorry guys didn’t see that you had already posted
                • B Offline
                  B Offline
                  Bananper
                  Now it's 50/50 mix, runs very well and cools good. But are there some bleeding screw or something to get rid of air? If so where do i find it?:)
                    B Offline
                    B Offline
                    Bananper
                    @declan Is there some bleeding screw, only for air?
                      Nah just run the bike with the coolant cap off for a few moments. Give the bike some revs (the coolant impellor is fed off the crankshaft).
                      • Irongamer727I Offline
                        Top up the coolant and let the bike idle with cap off. Be patient, after a couple of minutes it will start to bubble. Then, a couple of minutes later, rev it slightly and watch more bubbles escape. I did this for a good 20 minutes. Note that there will be bubbles left, but once you get most out there should be no cooling problem.
