  3. Exhaust
  4. DEP vs RomeuHenriques
25 Posts 8 Posters 9.4k Views
  • P
    P
    PJT95
    Cool, thanks for the info @Calum will be having a read later on.
    • P PJT95
      @pjt95 Just imagine if there is a hole in your exhaust, that sound wave won't propagate properly. If it does it may push lost fuel and air out the hole, making the next ignition sequence lean. Since you can see the green (fuel/air) charge is usually pushed back into the combustion chamber. Back in the day, there was no such things as expansion chambers, the bikes were jetted accordingly. Yours is jetted to take use of that chamber. No chamber will mean less fuel/air.
      We're talking minutes amount at this moment in time. And of course it's all hypothetical. But you asked.
      • P
        P
        PJT95
        Thanks for the info @Calum , really do appreciate it and have a better understanding now! as for the RomeuHenriques pipes, would you recommend one or would you just buy another DEP?
          @calum as a ball park figure how much could you expect to lose hp wise on my project bike I can put my hand over the exhaust and it will continue to run perfect the leak is that bad now the bike only has 2.9hp Iโ€™d expect to lose 2hp so Iโ€™ve only just been thinking this is most likely why it has zero torque/power
          • P PJT95
            @pjt95 I went with a Romeu pipe myself, because no matter how hard I tried, the DEP insisted on rotting.
            @declan I'd expect the majority of the power to go if the pipe is that bad. But it all depends on where it is. On a bike with only 2.9 hp, I'd be surprised if the exhaust was even setup properly in the first place. But a decent exhaust on a two stroke, is the difference between naturally aspirated and a turbo engine. The two stroke pipe supercharges the engine. So it's imperative that it's working effectively.
              @calum you think an underslug romeu would work with the 170 kit? Does this Romeu make "regular" pipes as well? Currently have an arrow pipe but it rots fast
                @irongamer727 Pipes needto be suited to the engine. But athena is quite common. Ask him, he's pretty knowledgeable.
                • Y
                  Y
                  Yegor
                  wrote on last edited by Yegor
                  @Irongamer727 I have asked him about 170cc kit and the answer was " if you do not tune the Athena kit that exhaust must go good " .
                  • Y Yegor
                    @yegor the underslug?
                      @irongamer727 Hhmm, it seems like he and I share the same opinion of the Athena kit it would seem.
                        Have just fitted a Romeu exhaust and it is impressive, can't comment on durability or performance as yet. Have a new Dep exhaust that came with the boxed up 88 and was going to get it plated over to try and counter the rot problem. Anyone tried that or any other remedy? Personally would not purchase Dep due to reputation. The seller I bought the bike said he had rejected the first one sent as already had rust on joints.
                        • O oldman
                          @oldman so I had a rotten big one I sanded it down and painted it black now itโ€™s like new but obviously you lose the shine but I love it all the same
                            @calum which is?
                              @calum which is?
                              @irongamer727 My understanding is that the port timings for the 170 Kit was based off the DT200R. As such the ports are 3mm too low. People have shaved 3mm off the head and shimmed it at the base to correct this.
                                Here is the link I found when browsing.
                                http://www.125ccsportsbikes.com/forums/index.php?showtopic=100859
                                Years ago now mind you.
                                • P
                                  P
                                  PJT95
                                  Just wanted to update this thread and say I got my romeuhenriques exhaust.
                                  My DEP has a small hole near the cylinder head, so thought I'd treat myself.
                                  Before hand, I was struggling to get 60mph in 6th out of my bike with the DEP on. With the new exhaust I'm in 4th gear at 55-60.
                                  The powerband is a lot more prominent and you can feel it actually pull you back.
                                  The bike also comes up in 1st 2nd and 3rd with no clutch, just raw power.
                                  Thought I'd update this thread incase anybody is sitting on the wall debating if they should get a DEP or spend the extra money and get the better exhaust. ๐Ÿ™‚
                                  • P PJT95
                                    @pjt95 Performance wise, I found the DEP very good. It was just that it rusted so easily. I hope the stainless option lasts longer.
                                    • P
                                      P
                                      PJT95
                                      Yeah I think it was the crack that caused the lack of power from the DEP. However when I first got the bike, it had power but not as much power as it has now. If you are looking for best bang for buck, I'd go with the DEP. But if you're looking to get the most out of a DT, I think Romeu is the way to go if you have the cash. ๐Ÿ˜„ I'm so surprised with the amount of power the bike has now because I've been without it for so long!
                                      • B
                                        B
                                        Bananper
                                        #24
                                        DEP is a good pipe, fair enough. But it lacks a big amount of power in the powerband, i find giannelli/arrow to be the most fun AND powerful. I think DEP might be good for trails riding, since you can control the bike a lot with it.
                                        I'd love to have a Romeu, never tried one. But in videos and stuff it sounds amazing
                                        • P
                                          P
                                          PJT95
                                          Its sounds a lot better in person and the videos don't really do it justice. I have a video of when I had the DEP on, so I'll put my gopro on tomorrow, get a quick vid of the romeu and post it on here as a "comparison" for anyone interested
