  4. Twin radiator
Twin radiator
30 Posts 5 Posters 7.3k Views
    @ryanjimccfc Waterless coolant will result in it runner hotter.
    R Offline
    R Offline
    ryanjimccfc
    @Calum okay then I won't bother with that what second radiator can I use
    • R ryanjimccfc
      @ryanjimccfc You can use whatever radiator you want. Just make up some brackets for it to fit.
      R 1 Reply Last reply
        R Offline
        R Offline
        ryanjimccfc
        @Calum I do have a set of wr200 radiators from a previous project but there are smaller in size than the dtr is it worth doing both or just simply adding the 1 extra they are shiny alloy so they look a lot nicer
        • R Offline
          R Offline
          ryanjimccfc
          It's a shame I don't have a dt200 one cause that would bolt straight on
          • Glynn123G Offline
            Glynn123G Offline
            Glynn123
            In the heights of summer hammering my DT flat out for hours on end through mountain passes etc I seen a maximum of 80 degrees c after sorting my cooling system and head gasket out. Heard the same from others over in Norway and Germany, even with higher tuned DTRs during long burnouts etc. I know when I used to do alot of trail riding in humid woods my DT would sit at around 80 degrees in summer, where my trials bike would occasionally boil. Theres nothing wrong with the standard cooling system, im pretty sure BARacing are still running single rads on their bikes also.
            • Glynn123G Glynn123
              R Offline
              R Offline
              ryanjimccfc
              @Glynn123 that may be the case but mine is not good enough for what I'm doing with it hence the post
              Glynn123G 1 Reply Last reply
              • R Offline
                R Offline
                ryanjimccfc
                How do I go about plumbing it all up just y piece it all In?
                • R ryanjimccfc
                  Glynn123G Offline
                  Glynn123G Offline
                  Glynn123
                  @ryanjimccfc just saying you should possibly look elsewhere, sounds as if there's a problem in the cooling system to me 👍
                  • BluestoesonnoseB Offline
                    Bluestoesonnose
                    I'm guessing these overheating bikes a a tip top cooling system, with a rad in A1 condition, pump working as it should be, cooling galleries in the head and barrel free from corrosion and debris, etc, etc? As these bike are sold worldwide with the same cooling system and some areas of Europe have higher temps and higher altitudes than we see.
                    2002 DT125R
                    • R Offline
                      R Offline
                      ryanjimccfc
                      I've got A new radiator new pump it's a brand new top end all new cooling hoses good quality Coolent no air locks digital temp gauge so I can see what's going on and the bike is getting to hot it's getting to like 110 115 and personally I think that's way to hot I even have a cooling fan not a pc one a proper radiator fan to help with air flow when I'm off roading and I just carnt seem to get control of the temps which is why I'm wanting to try a twin radiator set up
                        Bluestoesonnose
                        Engines running lean run hot, whilst 2 strokes perform better on the edge of seizing is this what you're looking for, or would it be worth trying to richen up the motor a little and see if the temp drops as something doesn't seem right. I've tuned quite a few bike and car engines over the years and only minis and imps had issues that required doubling the size of the rad.
                        2002 DT125R
                        • R Offline
                          R Offline
                          ryanjimccfc
                          Okay I'll look into the jetting but bike runs really well with jet it has I'm not saying it the right jet but I thought it would have a white plug if lean
                            Bluestoesonnose
                            Hi Ryan,
                            Just checked through some old photos of my RD350LC I had in the 80s with a Stan Stephen's stage 4 barrel porting on it, head lapped to the barrel, microns, KnN pod filters and running on 4 star and it was on a std rad.
                            Thrashed everywhere the temp was in normal limits.
                            2002 DT125R
                              Bluestoesonnose
                              Hi Ryan,
                              Something that just entered the old grey matter, is the rad cap the correct one, in good condition and is it rated for UK ambient conditions?
                              If you're not able to get the system at the right pressure the water will overheat and you will have cooling issues. It could be worth splashing out on a new genuine rad cap.
                              Cheers
                              2002 DT125R
                                Hi Ryan,
                                Cheers
                                R Offline
                                R Offline
                                ryanjimccfc
                                @Bluestoesonnose It's a genuine cap
                                • R ryanjimccfc
                                  Bluestoesonnose
                                  @ryanjimccfc Is it in good condition, could be worth trying another one to ensure you're getting the correct pressure.
                                  2002 DT125R
                                    Yes it is possible.
                                    M Offline
                                    M Offline
                                    mhbikesnbits
                                    @Calum I know this is a old post but what twin radiators are you running here ?
                                    • M mhbikesnbits
                                      @mhbikesnbits Yamaha DT 230 Lanza radiators.
                                      I've finally got this running perfect now! Dead on 60 degrees under full load. So well happy about that.
                                      M 1 Reply Last reply
                                        M Offline
                                        M Offline
                                        mhbikesnbits
                                        @Calum oh really I gotta do myself some twin radiators for my 200 engine were they compatible with the standard dt brackets you can get the Lanza in aluminium too which would be nice to have
                                        • M mhbikesnbits
                                          @mhbikesnbits said in Twin radiator:
                                          Those Aluminium ones are not Lanza radiators.
                                          I bought a set of those last year and to my dismay they are not even remotely the same. Not sure why they call them Lanza Radiators???
                                          I have a DTRE and the fairings mount the same as the Lanza's, so R models won't be a direct fit, small bracket to hold the panels on. I actually welded on a bracket to improve the fitment.
                                          As you can see, it's basically an RE.
                                          You will want the mounting hardware for the Lanza radiators ideally. But once you have that, it's a direct fit onto the RE frame.
