  4. removing flywheel on a dtre
2 Posts 2 Posters 506 Views
  • B Offline
    B Offline
    Bananper
    I'm getting a new (used) engine for my dt, only thing i have to do is to put my carb, pv and flywheel over on the new engine and it should work. Anything i need to know about? do i need any special tools to get the flywheel off?
      You'll want a fly wheel puller. And you'll need to lock the crankshaft off to remove it.
      Pretty simple job though.
      https://www.ebay.co.uk/itm/PRO-13PC-HARMONIC-BALANCE-CRANKSHAFT-GEAR-PULLEY-PULLER-FLYWHEEL-BALANCER/122134506298?_trkparms=aid%3D555017%26algo%3DPL.CASSINI%26ao%3D1%26asc%3D53530%26meid%3D7ad1578465b741d992b0a55ca04a7f02%26pid%3D100505%26rk%3D1%26rkt%3D1%26%26itm%3D122134506298&_trksid=p2045573.c100505.m3226
      That for a DTRE, you'll need a different one for a DTR.
