  4. Top end gasket kit
Top end gasket kit
4 Posts 4 Posters 535 Views
  • BluestoesonnoseB Offline
    Bluestoesonnose
    Quite a simple one, which top end gasket set is best to use, Athena, Yamaha, other?
    2002 DT125R
    B 1 Reply Last reply
      B Offline
      B Offline
      Bananper
      @Bluestoesonnose defo yamaha or athena, would not buy anything else as i have had a lot of issues with cheap gaskets
      • Sgt Robuck 5S Offline
        Sgt Robuck 5
        wrote on last edited by Sgt Robuck 5
        @Bluestoesonnose I wouldn't buy Athena mate. I've had 2 gaskets go on my dt. 2 of which were the transmission clutch cover gasket which caused an oil leak and now my head gasket has just gone! which is now drinking all my coolant. Buy OEM!
        • Sgt Robuck 5S Sgt Robuck 5
          @Sgt-Robuck-5 Sounds like a bigger problem to me. I highly recommend Athena and of course genuine.
          If the surfaces aren't flat then no gasket will seal. I always recommend a quick homemade skim on the head and cylinder before refitting.
