  3. Framework
  4. yamaha dt125 swing arm upgrade-help
4 Posts 4 Posters 986 Views
    jonathanslua
    Re: YZ Swingarm on DT?
    hello and good day! i have a dt125, i want to upgrade my swing arm. any suggestions? thank you!
      Are you willing to do custom fabrication? Or do you want something that bolts on.
      A DT200R Swing Arm or Lanza Swingarm is said to be a direct replacement that are both made from aluminium, although I'm yet to see a ally Lanza arm.
      Otherwise, there is no reason why a YZ arm couldn't be made to fit, it's a lot of work mind you.
      • Louis-DT-WRL Offline
        Didn't the TDR 125 and maybe 250 have an aluminium arm? Best best is the steel frame tdr125
        • MadGyverM Offline
          MadGyverM Offline
          DT200R alloy swingarm is direct fit,I've done it,you will need the wheel spacers also,I forgot them and had to custom fabricate.
