  3. DTX
  4. Crash bungs
Crash bungs
13 Posts 3 Posters 2.8k Views
  • jakeyboyJ Offline
    jakeyboyJ Offline
    jakeyboy
    Hi, wanting to put some crash bungs on my DT, anyone done this before that has some advice as don’t want to spend £70+ on front and rear r&g ones. Thanks!
    Glynn123G 1 Reply Last reply
    • jakeyboyJ jakeyboy
      Glynn123G Offline
      Glynn123G Offline
      Glynn123
      @jakeyboy I have, a meter of M8 threaded barrel and 4 nylock nuts - £2
      Some old skateboard wheels from a colleague - free
      Don't have any close up photos but they do the job and look reasonable I'd say
      • Glynn123G Glynn123
        NINJAN Offline
        NINJAN Offline
        @Glynn123 I take it that you swapped your axles out for the threaded bar???
          Glynn123G Offline
          Glynn123G Offline
          Glynn123
          @NINJA yeah weight reduction, there's Abit of slop in the wheels when you corner hard mind...
            NINJAN Offline
            NINJAN Offline
            @Glynn123 It that because the bar is thinner than the original axel's???
              Glynn123G Offline
              Glynn123G Offline
              Glynn123
              @NINJA only by about 19mm
                NINJAN Offline
                NINJAN Offline
                @Glynn123 DAMN that's a lot for-sure!!!
                jakeyboyJ 1 Reply Last reply
                  jakeyboyJ Offline
                  jakeyboyJ Offline
                  jakeyboy
                  wrote on last edited by jakeyboy
                  @Glynn123 thanks for help, any chance you can attach a photo of the threaded bolt or a link please. The bolts I’m finding don’t seem to look like they’d work 🙂
                    NINJAN Offline
                    NINJAN Offline
                    @jakeyboy @Glynn123 Is your man for that dude. 😉
                      jakeyboyJ Offline
                      jakeyboyJ Offline
                      jakeyboy
                      @NINJA oops yeah, didn’t mean to @ you haha, cheers
                      • Glynn123G Offline
                        Glynn123G Offline
                        Glynn123
                        Something like this would do the job, you'll have pleanty spare at 100cm, https://www.ebay.co.uk/itm/M8-M10-M12-1-0mm-FINE-PITCH-Threaded-Bar-Rod-Studding-Full-Nuts-Washers/292737174175?var=&hash=item44287eca9f
                        Just select M8 diameter as it fits the drilled axles rear axle nicely. You might want to check the diameter of the drilled part of your front axles mind, I don't have standard forks and axle so it may be slightly narrower and need drilled out for the bar to work.
                        Also you'll probably get the threaded bar and nuts allot cheaper from a local firm, I think I only paid a couple quid if that.
                          jakeyboyJ Offline
                          jakeyboyJ Offline
                          jakeyboy
                          @Glynn123 thanks pal, will get it measured up then and get them ordered
                          • jakeyboyJ Offline
                            jakeyboyJ Offline
                            jakeyboy
                            Has anyone put on front axel sliders on stock DT suspension? As both sides are different diameters.
