  3. Brakes
  4. Brake callipers upgrade
11 Posts 3 Posters 1.6k Views
  • M Offline
    M Offline
    mhbikesnbits
    Looking for callipers options for the dt125 to upgrade both front and rear callipers two pots or 4 pots would be desirable option
    N 1 Reply Last reply
    • M mhbikesnbits
      N Offline
      N Offline
      @mhbikesnbits There are none without changing the whole front end and manufacturing new brackets.
      • M Offline
        M Offline
        mhbikesnbits
        Yeah I though not but worth the ask any single barrels that fit
          I run Aprilia RS125 Brakes on my DT. Stopping power off the head!
          M 1 Reply Last reply
          • M mhbikesnbits
            N Offline
            N Offline
            @mhbikesnbits Read through the threads in the brake section bud, many of the questions you will most likely ask have already been answered there. 😉
              M Offline
              M Offline
              mhbikesnbits
              @Calum they straight fit or custom bracket
              • N NINJA
                M Offline
                M Offline
                mhbikesnbits
                @NINJA yeah had a little look but like to ask the question to fresh faces
                • M mhbikesnbits
                  N Offline
                  N Offline
                  @mhbikesnbits LOL nothing is a straight fit, as the crappy single pot brackets and even crappier disc bolt spacing's make it a nightmare. You would be better off doing a USD conversion and using those forks to get better brakes. Which would save you some major headaches and much expense in the log-run. 😉
                  • M mhbikesnbits
                    @mhbikesnbits No but a bracket is simple enough to make.
                    • M Offline
                      M Offline
                      mhbikesnbits
                      easy make yeah but sometimes I think they look like the bikes over engineered if you know what I mean
                      • M mhbikesnbits
                        @mhbikesnbits Have woeful brakes then.
