Dt125re 2004 servo
Technical Zone
11
Posts
3
Posters
1.0k
Views
Watching
Yes, if the engine hasn't been run, then the servo will only sweep one way. Then when the engines running, the powervalve moves. Then if you turn the engine on and off, it'll do the full cycle again.
I had this when my CDI went faulty.
Could be that you haven't adjusted it appropriately, or the cables are the wrong way around.
Disconnect the cables from the valve then do it. Does it still do it,.
@Jgb19830 Meh? Gets old quick. Noisy but fine once past 6k
I like to disconnect it for a grin now and then!
@Jgb19830 Okay, yeah how interested. CDI could be faulty.
I'm not sure how they work under the hood.
